Green Coils Mikes XS
  • Filter
  • Green Coils Mikes XS
    Been searching for the last 45 minutes. I thought I've read this before.
    2- Mikes XS green coils, 4 - 5k ohm caps, and 4 - wires are on there way in from Mikes XS. Do I need the ballast resistor?
    Getty
    1980 SG
  • #2
    Dude
    I dont think so .If your bike has one bypass it by plugging one plug into the other .
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • #3
      The Ballast Resistor is to be removed. The coils will not get the proper voltage if used. Like Axel said just remove it and plug the two wires together. I suggest wrapping it in electrical tape also so it does not come appart on ya and short out.
      Ozz
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • #4
        Definitely bypass the resistor. I didn't at first and it ran, but it ran like crap.
        I know this, because Tyler knows this.
        1980 SG
        3J6 003509
        Kerker 4-1 (sans baffles)
        Fuse Block Upgrade
        Mike's XS Green Coils
        Pods w/Homemade Velocity Stacks
        • #5
          Thanks guys! I removed it. Coils and new tires should be in today. Gaped plugs at .034
          Had one bent rotor. 25$ to fix at Woody's Wheel Works here in Denver.
          Filled bars with silicone(interested to see if it improves... cant hurt anything) Ordered the SS Brake Lines off ebay (next week upgrade)
          This all came about when I thought I wanted a bike built in the 21st century. After riding many bikes, I decided my XS1100 is perfect. No new bike for me.
          Getty
          1980 SG
