Leaky carb?
  • yamaphil
    • 10
    • prince albert sk canada
    Leaky carb?
    I've got one of swivels on the carbs is leaking on the left side , I'm not sure of what its called , but its the part of the carb the swivel that connect the carbs. if anybody has any sugestions or any way to fix it, it would be most helpful. thank you.
    Do you mean the fuel tee?? Is it the part where the fuel line form the tank connects to? That will require removing the carbs and pulling them apart and building or buying new fuel T.
      • 1347
      Go here for ideas and pics:
      read the entire thread...Lots of options here for leaking fuel tees
      • foreda
        • 949
        • Southwest Louisiana
        Fuel tees
        If you have to take them apart, you may as well change the butterly shaft seals as well. You can get them from Mike's XS. May save you some headaches later down the road. Jus a thought.
        78 XS1100E Standard
        Coca Cola Red
        Hooker Headers
        http://i408.photobucket.com/albums/p...m/DSC00580.jpg
        1979 XS1100 Special
        http://i408.photobucket.com/albums/p...m/DSC00612.jpg
        1980 XS Standard
        http://i408.photobucket.com/albums/p...m/DSC01137.jpg
        2006 Roadstar Warrior
        http://i408.photobucket.com/albums/p...um/warrior.jpg
        • yamaphil
          • 10
          YEP, it was the carb tee. i got them fixed and away I went. thaks for all you help
            Congrats on fixing your problem!! Ride safe and enjoy!
              • 2078
              How did You solve the leaky tee problem?
