Take those chrome caps off your swingarm and tighten those nuts up like a wheel bearing. Tight-ish.. but not really tight.
I have read about the "hinge" effect on these heavy bikes if you attempt to push them a bit. I am not sure if I am "pushing" too hard on the bike right now, but there is a sort of a loping up-and-down aspect to the bike when it is being set into a corner at speed. It feels like the front wants to scrub out and the rear wants to do an independent slow-speed, roller-coaster impression. The bike behaves better with a full tank of gas and if I take great care to move my weight to the sweet spot of the bike where the wallowing is minimized. It is still a bit disconcerting. I feel like I am just "holding" the bike a bit away from being in trouble..
Tires are good, SF with special tank, tkat brace, sweeper curves at 55-60mph are where things get interesting..
A quick update on suspension mods would be appreciated. I have read the FAQ's but this was the first time that I had read about swing arm bearing adjustment and wondered if there was something else that I had missed.
Regards,
Gareth.
) I have noticed some of the wobble when doing that, but it seems that most of it is rider caused, either me moving wrong, or getting scared and backing out of it. I can go all the way to pipe dragging at those speeds without problems, if I can keep my mind in it. Sweepers I can take at WOT. 60 is pretty slow, and I have not seen much for handling problems at that speed.
I've yet to put in a set of Progressive front fork springs, but I did put on a TKAT FB, and the front end definitely felt much more stable..and I had a flimsier setup with 4" over length upper fork tubes!
I also pulled apart the steering head, cleaned the races and bearings and repacked, and it's totally smooth, no binding or notching!
