battery warning light
  • zx11racr
    • 101
    • kansas City, Mo
    In the tech tips it states to use a 2000 ohm resistor 1/2 watt. Could not find one at radio shack. Can I use 2 1000 ohm resistors in line?
    ed
    • 7818
    You SHOULD be able to find a 2K Ohm resister. If not, try a 1.8K ohm. Either one should work. The other way of trying it is with 2 4K ohm resisters in parallel. That will give you 2K across them.
    • zx11racr
      • 101
      • kansas City, Mo
      resistor
      The local radio shack didnt have one. I bought a package if 1000 ohm resistors thinking i could install 2 of them in the wire.
      ed
        Hey Ray,
        I'm no electrical guru, but I thought my understanding of basic resistance is that it's additional when in series....like the Ballast resistor which is 1.5 ohms, and the 1.5 ohm coils which has a total of 3 ohms resistance which is what the TCI needs to see!
        SO...two 1000 ohm resistors in series should work the same as two 4k ohms resistors in PARALLEL. I remember being informed about 2 parallel loads puts 1/2 the resistance vs. a series load.
        ZX11..if you have an ohmeter, wire the 2 resistors together and test them with the meter, I would expect it to read close to the 2k value.
        • oseaghdha
          • 1075
          • N43.02.5,W88.14.2
          Hey Ray,
          Yep, that's the way it works, except for parallel resistance is a little more complicated than that.
          XS1100SF
          XS1100F
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            Actual value is not that critical...seems there is a lot of leeway. A 2.2K Ohm works just as well.
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
