While not my most technical conversion (EFI, GM-DIS, Hydo-Clutch, LED,...), the XJ stator swap is a success. For me, it was a necessary project as the XS stator was barely making 12 volts at 5k RPM and as low as 11.3 volts near idle. Even with all LED's, my busa fuel pump was eating to much juice. So, I decided to give the XJ stator a try. The most difficult part of swap was getting the XS stator rotor off of the crank. I bought a set of pullers and had zero luck. Then I came back to the trusty forum, did some research, and found that I needed a M16 with 1.5 fine pitch thread to pop the rotor off. THIS was the hardest part. The hardware store had M16 with standard 2.00 pitch and all the way up to M14 with fine pitch. BOO! So, I called all over hell's half acre (on a Saturday). I got 10 no's and one very useful recommendation to check out a place called Specialty Supply once they opened on during the week. The big shock wasn't that he had a M16, fine pitch, ~3" long bolt in stock, but that it was $0.78.
That would have been about a $4 bolt at the local hardware store.
Anyways, after that, I just bolted on the XJ rotor and stator, and the wire connections were a direct fit for my '81. I had read that some wires needed to be swapped around, but I had no such issue.
The final result; the bike makes high 12 volts at idle and mid 13's at 4k. One of these days, I hope to pop for Geezer's Regulator. And, my biggest worry turned out okay...the YICS sticker peeled right off.
![EEK!](https://xs11.club/core/images/smilies/eek.png)
![Wink](https://xs11.club/core/images/smilies/wink.png)
