Who likes what tires?
  • Xcess11
    • Jul 2008
    • 20
    • Las Cruces, NM
    I'm looking for peoples direct experience with tires on their XS's.
    I have an all stock 1981 Midnight Special 1100. I bought it last year with a brand new set of Cheng Shin Hi Max tires on it installed by the P.O.
    I've never had a bike with Cheng Shin's before (always thought of them as "cheap" knockoffs) but they seem to be generally OK.
    Things I do notice is a little bit of "hunting" from the front tire when I'm cruising in a straight line and they can be a bit too easy to "spin-up" if I give the XS throttle when leaned over in a turn. Balance would appear to be OK up to about 100mph, which is as fast as I've had the bike up to. I've only put about 2K miles on the Cheng Shins so far so I can't comment on overall mileage.
    I know this as an older bike and will not have the same the same handling characteristics as a modern bike with sticky 17inch radials but I can see that I would like a tire with more grip if I want to push the XS in the corners.
    What say ye keepers of the XS11 knowlege flame. Got any tire stories/experiences to share?
    What Is:
    2003 Kawasaki KDX 200
    What Was:
    2001 Yamaha FZ1 - WarpDrive!
    1987 Kawasaki ZL 1000 - Eliminator
    1983 Honda CR 250 Glamis Blaster
    1988 Kawasaki KDX 200 - Stolen!
    1974 Suzuki GT 750 - Water Buffalo
    1984 H.D. XLX 61 - Good Riddance
    1976 Kawasaki S3 400 - Two Smoke
    1979 Honda CB 750F - Black Beauty
    1974 Kawasaki H1 500 - Mean Green
    1971 Suzuki TC 90 - 15 Y.O.'s dream!
    OH NO!! Not ANOTHER tire thread!!
    Since you're new, I guess it's ok.
    There are TONS of opinions on tires, and you'll probably get a different one from every member here. The only thing I've really seen repeated as far as what people claim to be "good" tires are the Bridgestone Elite II or III. I have a Cheng Shin on the front of mine, only because I was looking for an affordable replacement, and the dealer said that's what they put on all their own bikes. I haven't had any trouble with it so far, but I don't push it really hard at all, as I don't want to find out first-hand what the limits are.
      I run the Dulop E3 tires front and rear on my 1980 MNS. I only have about 3K miles on them, so I can't comment on how long they will last. I WAS able to put a 140/90/16 on the rear, with about a matchbook cover between the tire and swing arm. You need a blackwall tire to do this, raised white letters or whitewall WILL hit. The front was the stock 100/90/19, as the Special forks/brakes makes it almost impossible to put on a 110. Handling is good, and the tires still look like new.
      Look for my bike on a trailer in your area August 21-22. SWMBO and I will be in Santa Fe that weekend, and then go through ABQ on the way to Sedona. I'll be staying at the Hampton Inn Los Alamos for the two nights. The price for a hotel in Santa Fe was WAY to high! I will be riding the bike once we park, and if we can meet up you can see what the tires look and feel like.
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        On my 1978 E I have ran Metzler ME880's and (currently) Dunlop K491 (Elite II). I'm happy with both.
        On my 1980 LG I have Dunlop GT501 (arrowmax). Not as long-lasting but better 'adhesion' as this bike has some performance mods.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
        • cueball
          • Jun 2003
          • 375
          • Nth Albury NSW Australia 2640
          Shinko
          Tyres, don't know if you lot get this brand up there. Have used "Shinko" tyres on XS11 and FJ11, work well on both and reasonably priced.
            ......are the Bridgestone Elite II or III....
            I meant Dunlop... Sorry.
              The 'Hi-max' is the CS mileage tire, and is a bit hard traction-wise if you get carried away. That will be true of any of the long-lasting tires (contrary to what may be claimed by some; they're just not riding that hard).
              Personally, I've been using Cheng Shin Barracudas for years and have always had good luck with them. They don't last as long as the high-priced 'name' brands, but for me they last about 70-75% as long and cost half as much (or less), so that's a pretty good return.
              But 10K or a bit is about the very most you can hope to get out of any rear tire, and that's riding fairly gently. Ride real aggressive with a sticky tire and you can get that down to about 3k. Me, I get 5-6K out of a rear tire and replace the front every other rear.
              '78E original owner
              • Ivan
                • Jul 2008
                • 2524
                • Hutchinson KS
                Bigfoot turned me on to Shinkos which are less than $100 shipped from the Motorcycle Superstore PER SET! I got a couple thousand miles in on mine before the wreck, and I was very impressed with them. Traction was good, wear was good. Seemed to be a good all around tire.
                Bigfoot has some more miles on his, I think Russ said close to 7k, so he would have a better evaluation. Hopefully he can chime in with some wisdom and a link.
                Ich habe dich nicht gefragt.
                  • 2117
                  Love my Metzlers.They are a great tire in the rain and wear very good.
                  • foreda
                    • 949
                    • Southwest Louisiana
                    Tires
                    I like mine round!!
                    78 XS1100E Standard
                    Coca Cola Red
                    Hooker Headers
                    1979 XS1100 Special
                    1980 XS Standard
                    2006 Roadstar Warrior
                      Originally posted by foreda
                      I like mine round!!
                      Tires are round, and pi R squared!
                      • Bigfoot
                        XS-XJ GURU
                        • Sep 2005
                        • 1422
                        • Kansas City, Missouri
                        Yep, I have a set of Shinko's on mine. After doing a little research I found out that Yokohama sold their motorcycle tire division to a Korean (I think) company including all of thier tire compounds. I decided to try them out, they had excellent reviews every place I saw them. They make 1 model that is bias ply and the correct size. The best part is the price. I think it was $53 for the rear and $41 for the front with free shipping from motorcycle-superstore.com
                        They balanced up real nice and stick to the road very well. Wet or dry, I never once felt like the tires weren't solid on the road. They also ride nice. No complaints.
                        I have almost 6000 on the tires now. The front has almost no wear on it. The rear has maybe another 1000 left on it, so the mileage isn't that great. But, for $53 I have another waiting to go on. Even if I go through a couple a year, I am still ahead over some of the other brands.
                        Harry
                        '79 Standard
                        '82 XJ1100
                        '84 FJ1100
                        Acta Non Verba
                          I challenge anyone to come ride with me and see if they think the tire is being ridden hard. I haven't met anyone yet, since owning the bike several years now, that rides them harder than me. I don't think I would have any trouble getting several people to vouch for that.
                          The thing you aren't looking at is dual compound. Many modern tires have a harder center composition and a softer side for corner grabbing. The center of my tire looks smooth, but the outside looks like scrubbed eraser. I run the bike often as fast as it will go, do lots of wheelies, hard squeeling stops, hard runs off the line, SUPER hard cornering and have run down many many modern bikes in the twisties. They will overpower me in the straights, but I'll suck them up when the road turns.
                          Riding the way I do, I got over 16k miles out of my last Elite 3 rear tire and it wasn't bald yet. I don't think I will see 16k out of this current one, but should have no problem getting 12-14k. You will often see different mileages from the same brand/make tire from one set to the next, but even this reduced mileage this time is @ double the next best tire I have had on.. the Avon Venom at @ 7800 miles.
                          The thing about the Elite 3s is that they probably have 2-3 times the amount of rubber in them that other tires have. This makes for a stiffer sidewall.. which makes for a better cornering bike. I can take this tire to the highest speeds on the corners without feeling like the bike has a hinge in the middle of it. I can still get it to do that.. and remember the XJ has a built in fork brace.. but it takes a lot more effort to do so.
                          Some have mentioned problems with the Elite 3 front tires and rain. I have only had one on the front for a few thousand miles and only one rainy day, but had no problems with it then. YMMV.
                          The Brigestone Battleaxe has been the worst rear tire by far, followed next by a Dunlop 404. The best FRONT tire I've used so far was the Avon Venom. It and an Elite 3 back has been the best handling setup I've had so far, but as stated, I haven't had the Elite 3 front on very long. Cheng Shins aren't a bad tire in a pinch, but I noticed they tended to cup pretty bad, and they aren't dual compound last I checked.
                          So.. short story long.. . Anyone who says you can't have high mileage AND a good sticking tire, doesn't know what they are talking about.
                          • foreda
                            • 949
                            Pi
                            Noooo.. Pi are round,it's corn bread that's square!!
                            78 XS1100E Standard
                            Coca Cola Red
                            Hooker Headers
                            1979 XS1100 Special
                            1980 XS Standard
                            • Bigfoot
                              XS-XJ GURU
                              • Sep 2005
                              • 1422
                              I can vouch for his riding style He is definitely not exagerating. LOL
                              Harry
                              '79 Standard
                              '82 XJ1100
                              '84 FJ1100
                              Acta Non Verba
