1979 F w/Yamaha fairing, hard bags, the fuse box has been replaced with inline blade fuses (not pretty but it works). Battery is fully charged.
The left side signal works fine front and rear, the right side lights up front and rear but will not flash.
I rebuilt the left handle bar control and it seems to work fine. I have tested with a known good left control from a 1979 SF and get same test results.
I have tested the flasher relay on another bike and it seems fine and also used a known working flasher relay and left side works - right side does not. When holding the flasher relay in hand and activating the signal control I can feel the left side pulse and tick, when the right side is activated it clicks on but does not flash.
Voltage is 10 on the left and varies as the flasher works, voltage goes to 10 on the right and holds.
I unplugged the signal canceling unit and it has no effect on test.
I tested the ground on both rear lights and it ohms out good.
The faring running lights work fine both right and left.
I would appreciate any feedback – I am certainly not a DC electrician.
