clutch slips in 3rd
  • zx11racr
    • 101
    • kansas City, Mo
    clutch slips in 3rd
    I have searched this but was wondering what clutch you recommend and I might try new clutch springs first. What brand springs do you guys recommend?
    ed
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Hey zx11racr,
    I bought friction plates from partsnmore.com and kept the old springs... Seemed to solve my clutch slip, my new springs were incorrect ones from JCWhitney. I plan on getting a new set from MikesXS.net and changing them later. Check these threads out you might find what your looking for. Good luck, such more there's a lot more info on here about it and other solutions as well!
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • red bandit
      • 950
      • central michigan
      I fought this same isssue for over a year. Slips in 3rd when it hits 7K. I tryed new Vesrah HD springs, a little better but still slips. Diff. oils, added a steel, no better. Three diff. clutch packs. Put in Barnnet springs w/o the extra steel, still slipped. Bought P&M clitch frictions, problem solved. After I added the extra steel that compressed the springs so they are under length spec.
      79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
      79 SF parts bike.
      • 81xsproject
        • 3185
        • Fortuna, CA
        Learn from red bandit and my own mistakes. Go all out the first time. Iwent into my clutch three times. Get heavy spring, lightly sand yours steels to remove glaze, add a steel, and replace all your fibers. Barnett is the best, Versah is good, too.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • oseaghdha
          • 1075
          • N43.02.5,W88.14.2
          I just replaced the springs with a heavy duty set and installed new frictions with sanded steels. No problems anymore. Used to slip in 3,4,5th over 5500.
          XS1100SF
          XS1100F
          • Bigfoot
            XS-XJ GURU
            • Sep 2005
            • 1422
            • Kansas City, Missouri
            Ed, this might be something to work on next Sat. Simple things first, I am assuming that you have adjusted the clutch as per the manual? The clutch on my midnight has been slipping in higher gears as well. Thinking about adding another steel.
            Harry
            '79 Standard
            '82 XJ1100
            '84 FJ1100
            Acta Non Verba
            • zx11racr
              • 101
              • kansas City, Mo
              clutch
              Yeah I adjusted the clutch but it was after my ride. I havnt been back out since. This was a common problem with the xj650 and xj750. We always just put new clutch springs in and that fixed it. I dont want to do it more then once though. Only happens when you are on it hard. Like maybe going up a entrance ramp. My just get new frictions and springs and do it right the first time.
              ed
              • Bigfoot
                XS-XJ GURU
                • Sep 2005
                • 1422
                At least the clutch is easy to work on, don't even have to drain the oil.
                Harry
                '79 Standard
                '82 XJ1100
                '84 FJ1100
                Acta Non Verba
                • zx11racr
                  • 101
                  • kansas City, Mo
                  clutch
                  True, I might just order new frictions and springs. Where would you get them from?
                  ed
