Uncertain Electrical Failure
  • xs11bobber
    • Jun 2009
    • 229
    • Cromwell, Indiana
    I haven't found a right control with 5 wires on ebay yet, so I improvised. I put a jumper wire where they would plug in. Well, at first I wasn't sure of which R/W. I looked in the clymer's and kinda dropped it on my frame and it started cranking. It surprised me and I instantly disconnected the jumper. It didn't crank hard so I put the charger on it. Now I can't get the bike to crank at all. I've removed all electrical tape from the harness and nothing looks bare. I've got one odd connection (battery +) that's more like a 6ga. butt connector. Wiggled it a bit and nothing.
    I had the battery charger on the lowest setting being 2Amp slow charge. I touch the starter to the + and it cranks. Any advice?
    Josh Yoquelet -- I'm having dreams of my XS
    '79 XS11SF "stock"- 4/1 Kerker, T.C.'s fuse block
    '79 XS11SF "bobber"- Rotted in a pine tree for 10 years
    '81 Air forks w/23,000 miles
    New steering head races and bearings
    '78/'79 standard wire harness
    Drag bars, w/Mikes controls
    T.C.'s fuse block
    PNM Coils
    7mm Dyna Wires
    NGK Resistor Caps
    Custom 1" clutch and 9/16" MC
    http://xs11bobber.tripod.com
    Hey Josh,
    Sounds like if you were messing with the right hand control switches, you might have gotten the Emergency Kill switch in the wrong position or such. DO you still have the switch control plugged into the harness??
    • xs11bobber
      • Jun 2009
      • 229
      • Cromwell, Indiana
      No. My original controls have 3 wires, the knob wont turn, and the start button wont budge. I stole a harness from the 'ole man that he bought from ebay which I figured out has the 78E/79F right control wires.Since I don't have a set of right controls for it yet, I put a jumper on a R/W and L/W. Well, I was certain I had the right R/W at first then sat my clymers on the frame, which bumbed the wiring around the solenoid, and she started cranking then. Now I can't duplicate the result... I'm at a loss...
      T.C.'s fuse block
      PNM Coils
      7mm Dyna Wires
      NGK Resistor Caps
      • xs11bobber
        • Jun 2009
        • 229
        • Cromwell, Indiana
        Originally posted by xs11bobber
        Well, I WAS certain I had the right R/W at first then sat my clymers on the frame, which bumbed the wiring around the solenoid, and she started cranking then. Now I can't duplicate the result... I'm at a loss...
        I meant wasn't
        T.C.'s fuse block
        PNM Coils
        7mm Dyna Wires
        NGK Resistor Caps
          Hey Josh,
          I'm no Electrical GURU, and the wiring diagram doesn't make as much sense as I was hoping it would when I reviewed it!?
          The L/W=Blue/white wire is the wire from the starter, it needs to work thru a temporary switch to a black wire/frame ground for it to work.
          The Emergency Kill switch has the B/W=black/white wire running to it, and it needs to be NOT connected to a ground for it to be in the ON position. When it's turned to either side for OFF, it connects it to a ground, which deactivates the TCI.
          The wiring diagram shows the RED/WHITE wires coming into and leaving the right handlebar switch, but it doesn't show any switches that use them? It comes from the fuse panel, and then back out to provide power to the ballast resistor and low power side of the starter solenoid.
          SO...unless someone comes on here and corrects me, it looks like the Red/White wires would actually be connected to each other, and that the Blue/White wire should be connected to the starter button switch which should be connected to a black ground wire, or the switch should be grounded to the switch housing/handlebar/frame!
          • xs11bobber
            • Jun 2009
            • 229
            • Cromwell, Indiana
            so maybe I completed the ground circuit somehow when I sat my clymers down you suppose?
            T.C.'s fuse block
            PNM Coils
            7mm Dyna Wires
            NGK Resistor Caps
            • xs11bobber
              • Jun 2009
              • 229
              • Cromwell, Indiana
              Another go...
              I recieved my MikesXS right controls. I don't want to hack the wiring for them and I can use male spade connectors to plug into it, no big deal. This morning I duplicated a previous result like this...
              That's a jumper from blue/black to blue/white and another jumper on those to battery ground... it cranked~!~ This was right after replacing my fuse block with T.C.s fuse block. Now, I can't get anything. Checked the fuses, no problem there. Did the solenoid post/screwdriver test and it came good. Do I have something shorting out? Right when I think I get it, something screws up and I get frustrated and very discouraged. What a PITA. FRED! RANDY! ANYBODY! I need serious help.
              T.C.'s fuse block
              PNM Coils
              7mm Dyna Wires
              NGK Resistor Caps
              • xs11bobber
                • Jun 2009
                • 229
                • Cromwell, Indiana
                I might also note...
                that the MikesXS controls have 4 wires. Red/White and Tan which attach to the kill switch and blue/white and black which attach to the start button. I tried what looked to be the right way in my Clymers to attach a red/white to the blue white and then the blue/white to the blue/white and that was obviously wrong because I melted the start button to the spring. I tried the same thing but in reverse with the harness side and got nothing but a blown fuse.
                T.C.'s fuse block
                PNM Coils
                7mm Dyna Wires
                NGK Resistor Caps
                • xs11bobber
                  • Jun 2009
                  • 229
                  • Cromwell, Indiana
                  blue white
                  Oops. I keep doing that. I meant blue/black
                  T.C.'s fuse block
                  PNM Coils
                  7mm Dyna Wires
                  NGK Resistor Caps
                  • xs11bobber
                    • Jun 2009
                    • 229
                    • Cromwell, Indiana
                    Another little update
                    When I use a test light this is what I get to complete the circuit:
                    Test light on (+)[Key OFF]
                    Blue/White
                    Red/White
                    Test light on (-)[Key ON]
                    Red/White(same as one above)
                    Red/Yellow
                    So I put the Red/White from above and the Red/Yellow into 1 female spade connector and attached them to the Red/White on the switch then attached the remaining Red/White to the Tan from the switch which appears to complete a hot circuit. I then attached the Blue/White to the Blue/White on the switch and the Blue/Black to the Black on the switch. This gets nothing, but when I reverse the Blues, I turn the key to on, turn the switch and it immediately starts cranking and I can't stop it without disconnecting the wires. So reversed keeps a constant ground, but then why doesn't it work the "right" way?
                    T.C.'s fuse block
                    PNM Coils
                    7mm Dyna Wires
                    NGK Resistor Caps
                      You're making this much harder than it really is. There are only four wires to the r/h switch assembly, if there is no headlight on/off switch. The red/white or red/yellow (they look red/white in my Clymers diagram) go to the kill switch, the blue/white goes to the start button, and the black is the ground for the start button. The black will attach to the switch housing just inside the housing where the wires go into the housing. With the key on there should be power to one of the red/white wires in the bikes harness, and power to the blue/white. With the connecters disconnected, and the key on, jump the two red/whites in the harness together. That will simulate the kill switch in the on position. Next jump the blue/white to the black, and that will simulate the starter button being depressed. The bike should crank. If it doesn't crank, go to the starter solenoid and check the blue/white wire with you test light. With the key on there should be power there. If not the solenoid is bad. If you have power there then check again at the connector under the tank. If you have power then by grounding the blue/white should make it crank. If you don't have power on the B/W, at the connector, then you have an open in that wire. There are no other connectors in that circuit.
                      • Geezer
                        • May 2003
                        • 2985
                        • Willamina, Oregon 97229
                        When customizing switches, I find it's way easier to just take them apart and figure out what they do and attach the wire accordingly...
                        Geezer
                        • xs11bobber
                          • Jun 2009
                          • 229
                          • Cromwell, Indiana
                          Geezer
                          Yeah, I thought it would be that easy, lol
                          I can simulate this all day long. It seems as if when I hook it up to the switch with this same routing method, I get nothing. I checked the kill and it was working fine. Just my actualy start button, when I press it, doesn't do a damn thing. I took it apart twice and cleaned it, made sure it was functioning properly, and looked for manufacturer defects and everything checked out ok. Could it be my ground? Because When I installed new races, I repainted and cleared the upper TT. Is paint a circuit breaker?
                          T.C.'s fuse block
                          PNM Coils
                          7mm Dyna Wires
                          NGK Resistor Caps
                          • Geezer
                            • May 2003
                            • 2985
                            When I put black painted bars on my 79 Standard, I had to run grounds to the switches but normally there is a ground wire from the harness to the forks. If it's not there, you could have problem. Steering bearings were never meant to be an electrical conductor.
                            Geezer
                            • xs11bobber
                              • Jun 2009
                              • 229
                              • Cromwell, Indiana
                              Well I have a Black attached to the switch housing, but I don't have a black in the harness. I've been under the assumption that my Blue/black in the harness was ground for the switch. Maybe it isn't connecting properly? Because if I remember right I did clip the blue/white and blue/black together before and I still got nothing. I then took a jumper from the one of those gator clips to battery (-) and she cranked.
                              T.C.'s fuse block
                              PNM Coils
                              7mm Dyna Wires
                              NGK Resistor Caps
