I put in a spade fusebox, eliminated the RLU and put in a diode I picked up from radio shack. I started the bike once the harness was all taped back up and looked pretty. The headlight came on and functioned correctly. This was last night. This morning when I was getting ready to go to work, I revved up the bike just a touch and the headlight quit. It had popped the fuse. I put in another 10 amp fuse and everything worked correctly. I twisted the throttle just to see what happened and the fuse popped. I put in a 30 amp fuse because I had no others, the headlight worked. On my way home I found out I had no headlight. I pulled the side cover expecting to see a popped fuse, but the fuse is good, I pulled the bulb and it seems blown, there's soot on the inside but I have continuity through the filaments (this denotes a good bulb correct?). The bulb plug seemed like it may have melted a bit, so I pulled the seat and gas tank to see if my harness had melted anywhere else. I had taped the harness and then put the replacement diode in and taped over that. the tape seemed to be heat damaged slightly where the diode was, but not anywhere else. I pulled the tape off to look and the diode has localized soot around it (3/8 of an inch). I checked with my multimeter, all three of the leads in the headlight plug are grounded somewhere. When checking the fuse block the hot side is not grounded, but the other side is grounded. Am I going to have to take the tape off of the whole harness again? Where should I start? I'm going to check on getting a new factory diode from yamaha now. Pictures to follow in a little while.
There is a possibilility that I put the diode in the wrong direction.
, it has happened
