The jets just screw in and out - no adjustment. Be sure your screwdriver is in good condition and fits the slot absolutely properly. I would also use an impact driver the first time I was removing a jet that had been in place for a while - then you can be sure the screwdriver will not slip in the slot or twist off part of the soft brass head. The little buggers are pretty easy to damage, and although an impact driver sounds extreme, it is actually the safest way to go - just don't use your biggest hammer...
Idles but won't accelerate?
Bill, I spent two days tearing down and cleaning every mm of them carbs. All jets and screws came out, though some of the brass ones seemed to be brittle and chip a little in the slot head.
Anyho, now for the confession: I was adjusting the idle screw, on the second on with just two to go before I could claim victory, and the darn tip broke off as I turned it in while counting turns. Oops.
Do I need to get a new needle? Where would be the next question.
I think I may be all thumbs
Yes, and try www.motorcyclecarbs.com as they list them on the web site.Bill Murrin
Nashville, TN
1981 XS1100SH "Kick in the Ass"
1981 XS650SH "Numb in the Ass"
2005 DL1000 V-Strom "WOW"
2005 FJR1300 Newest ride
1993 ST1100 "For Sale $2,700" (Sold)
2005 Ninja 250 For Sale $2,000 1100 miles
Bill says you can still get them, but one day they will no longer be available so don't throw the broken one away.Brian
remembering the same thing!
The idle mixture adjustment screws are indeed still available from Yamaha, at least for the 78 carbs. Does anyone know if the idle screws that go in a 78 will fit and work in 79-81? Just curious. Btw, the screws are about $14 from bikebandit.
Also, just got my carb kits from motorcyclecarbs.com and they include the idle mixture screws along with jet needle, gasket, float valve, float seat, main jet, pilot jet, and some other type of jet that I haven't identified yet...prolly some type of air jet. They also include new c-clips for the jet needles.
Total for my 78 carbs: $115
I'm putting the kits in today hopefully1979 XS11F Standard - Maya - 1196cc (out of order)
Thanks for the advice.
I cleaned the carbs two times. Second time actually removing the jets and such. Broke the idle mixture needle in one carb, but got a replacement from a place for $8 in PA http://64.30.217.113/speedandsportinc/index.html . And one for $14.95 from http://www.motorcyclecarbs.com/, just in case ('cause I am all thumbs).
While I had the bike apart I replaced the coils with Dyna 2-1s for $108 from http://www.mpsracing.com/products/Dyna/ig01aa.asp.
Replaced a couple of dry rotten fuel lines. Pulled one pitcock off the fuel tank, drained and flushed the tank.
Bleed the brakes. For S and Giggles.
Finally put it all back together this afternoon and with a single push of the start button it purred like a kitten.
It idles like before at 1200rpm, but for now that's Ok. Maybe this weekend I'll try to adjust. I've got a synchonizer, but no "colortune" gadget. I put the new idle needle jet(pilot valve) in at 2 1/2 turns and it seems to sound ok.
Again, I appreciate all your advice and help. Now if I can just get ahead of the corrosion
Ray
Savannah, Ga
One small PS concerning the broken idle needle screw:
bought a set of tempered spring steel jewelers screwdrivers (about $6) and with a dremel shaved the smallest one down. Cut it off at a 1/2 inch and while holding it over the needle hole on the inside of the carb body with a pair of needle nose pliers another guy placed a large screwdriver over the top and smacked it with an adjustable. (not very technical, but it worked) Out popped the broken needle valve without dinging up the port.
Just thought I'd pass it along.
