About a month ago I started restoring my Dads 79 XS11SF. It's been parked in a barn for over six years. After scraping the bird crap off it, I started the process of rebuilding. I've repaired most everything from brake systems to body work to gear fixes. I can not begin to tell you how helpful this site has been! But on to the problem. Everything has gone well except the carb work. I'm way beyond triple cleaning. Here's what I've done.
1. Had the gas tank treated and sealed by the local radiator shop.
2. Removed and stripped carbs. Cleaned many times. put in new float valves.
3. New plugs ngk brand 6es or something like that.
4. Cleaned K&N Indiv. Filters
5. Applied the diphram coating fix, as listed in the tech forum.
6. Repaired and tested petcocks and Octopus
7. Replaced all feul lines and have verified the route with this site and clymers manual.
With that said here's the setup
1. Accell Super Coils and Wires (put on the bike back when it ran)
2. 4in1 kerker exhaust
3. Indiv. K&N Filters
4. Jets= 180 air; stock needle, needle jet, and pilot jet; 150 mains
5. My needle is set in the middle slot.
Here's the symptoms
Bike idles well both on and off choke. The transition from idle to mid kills the engine. If I crack the throttle she dies right at 1700rpm. If I ease the throttle she can reach 2500 but only for a moment then spits sputters and dies. I felt it was lean, so to test I let the bike warm up and then spray some starting fluid on the filters and crack the throttle. She runs like a champ ful rev no hesitation but only for a moment. I need your help...... what to do next?
Here's the symptoms
