I bought a Windjammer and hardware for my 82 XJ. Being that I bought it by a picture installed on another XJ, I assumed that it would bolt right up. When I finally got everything back to Michigan (Long story) I noticed it had '80XS1100G written on the bracket. I didn't think much of it at the time assuming the frames were all the same. But after I tried to install it, Something just didn't fit right. The bracket does not sit level. The "rear" part of the bracket that the jammer sits on, is lower than the front causing the jammer tilt way back.
So my question is...What is the difference between the 2 frames?
I'm not sure if I can use this bracket at all without some kind of "Mod".
I have had other "windjammers" on other bikes and the headlight just needed to be removed but I had a cover that went over the bucket to keep everything in that belonged and keep everything out that didn't. With this one I would need to remove the headlight bucket and the "ears" that hold it.
If someone has the correct bracket that they would like to swap for this one, that would be great.
Thanks
Thanks
(Sold back to Maximan)
Considering how easy it was to just remove it altogether, I'd suggest removing it and just zip-tie the wires into a nice, neat bundle.
