Originally posted by psycoreefer
View Post
End of that theory.
With regards to the evaporation thing, well, water evaporates from a smooth surface much more quickly than a porous surface, and although the fuel wouldn't get absorbed by the aluminum, the principle is the same and since the first theory doesn't hold water, then the second point is moot.
The third part is the absolute antithisis of ram-air....smooth surfaces create velocity....not bumpy factory castings. If you go down a water slide that is smooth, you will have more velocity than if you went down a water slide that is bumpy. Bumpy=friction. Friction=heat. Heat is not wanted in an intake charge.
Ram air has MORE effect at high rpm as the cylinder has LESS time to fill with the same valve lift as rpm increases.
But thanks for the info on IIRC!!!
