Petcock setting and fast idle
  • 777jfk
    • Jun 2009
    • 9
    • Lapeer, Mi
    When I bought my '79 XS 1100 Special a month ago, the previuos owner told me he always ran the bike with the petcocks set to PRI and never used the ON or RESERVE. I tried running the bike in ON and it starves for gas but it runs prefectly fine on PRI. The only issue is on some days, the it will idle at about 2500 RPMS. Normally it idles at about 500 to 800. Has anyone experienced this issue or have any suggestions?
    777jfk
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Sounds like you need to rebuild the petcocks. That and make sure that the vacuum lines to the petcocks are not leaking as they can cause both problems.
    Also the fast idle may well be caused by the bike needing a good sync, which includes setting the idle mixture, which from the sound of things might be too lean. Also 500-600 RPM idle is a bit low, these things were intended to idle about 1100 - 1200 RPM.
    • foreda
      • 949
      • Southwest Louisiana
      Petcocks
      777jfk
      I have a nice set of Special Petcocks I bought on ebay thinking they were for a Standard. Look in the Parts for Sale forum, I have pictures.
      78 XS1100E Standard
      Coca Cola Red
      Hooker Headers
      1979 XS1100 Special
      1980 XS Standard
      2006 Roadstar Warrior
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        Your high idle may also be a vacuum leak in the intake system.
        Petcock screens may be plugged up.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
          The high idle issue, might be an intermittent vacuum leak. Might look at changing the vac caps on the synch ports.
          The "petcock" issue is due to a faulty "Octy" since you have a special. On both models the fuel flow is controlled by a vacuum operated valve to only allow fuel flow when the engine is running. On both models, the prime position of the petcocks bypass this feature. On the standard models, the petcocks are vacuum operated to control fuel flow. On the special models the petcocks are NOT vacuum operated, they added a vacuum operated valve downstream. It sits on top of carb #2 and has four fuel lines, two in from each petcock and two out to each of the carb inlet Ts and it has a vacuum line that connects to the synch port on #2 intake, nickname "The Octy".
          That little bugger is why you have no fuel flow in ON or RES. Start by checking your vacuum line to it for leaks or kinks. Honestly, alot of folks just ditch the thing and make sure to turn the petcocks to off when your done riding.
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            It's even possible ...
            that that little bugger ...
            is not even on there!! You haven't said. When that little bugger is eliminated altogether, as many people do, the run position on the petcock becomes "PRIME". ... ON and RESERVE don't work at all.
            80G Mini-bagger
            Past XS11s
            • 777jfk
              • Jun 2009
              • 9
              • Lapeer, Mi
              Petcock
              You guys have helpful. I have to take my tank off to see if this could be the problem. I'll post if it is it.
              777jfk
              • thewiz
                • Oct 2006
                • 1115
                • Wilksboro, NC
                If the Octopus has been removed ...
                the front outlets on the petcocks should be capped off or otherwise plugged.
                80G Mini-bagger
                Past XS11s
                • Dragon Tamer
                  XStremely XSive(Deceased)
                  • Sep 2006
                  • 426
                  • Half way between Chili and Winter Wisconsin.
                  Wiz,
                  If you cap the front petcock tubes, then the on and off and reserve positions will work as intended and the prime position won't. This gives you an off position to shut off the gas when not riding and the on position when you are. It also will give you a working reserve. The prime and reserve positions both take gas from the lower tube of the petcock but deliver it to two seperate output tubes.
                  The Old Tamer
                  _________________________
                  1979 XS1100SF (The Fire Dragon)
                  1982 650 Maxim (The Little Dragon)
                  another '82 650 Maxim (Parts Dragon)
                  1981 XS1100SH (The Black Dragon)
                  If there are more than three bolts holding it on there, it is most likely a very important part!
                  • thewiz
                    • Oct 2006
                    • 1115
                    • Wilksboro, NC
                    You're right Dragon ..
                    Sold my Special a month ago now on which I had bypassed the Octy. Have apparently forgotten since then which outlet was which
                    Thx. for setting the record straight, sir.
                    80G Mini-bagger
                    Past XS11s
                    • 777jfk
                      • Jun 2009
                      • 9
                      • Lapeer, Mi
                      Petcock & Okty
                      The throttle stuck on my "79 Special when I opened it up all the way the other day so I shut the bike down with the kill switch and pulled over. When I went to see if I could get it unstuck, I knocked the cable completely off. This was about 5 miles from home so I put on the choke and limped the bike home. Did any of you know that these bikes will do 30 on choke if you take it through the gears. Anyway, when I got it home and started getting into it, I found that the fuel and vacuum lines were brittle and cracked. Since I was replacing them, I thought it would be a good time to take everyone's advice and remove the okty. I followed all of your directions and capped the front tubes on the petcocks to be able to use "On" instead of "Pri" like I have been since I bought the bike. Capping the front ones did not make the "On" work so I reversed them and capped the back ones. Now my bike works in the "On" position. It also has more power since I got rid of the vacuum leaks and the occasional fast idle issue is gone.
                      Thanks for all of the advise but remember to cap the back petcock tubes for the "On" position to work.
                      JFK
                      • oseaghdha
                        • 1075
                        • N43.02.5,W88.14.2
                        JFK
                        Or..............put the left petcock on the left side and the right petcock on the right side.
                        "OFF" is handle towards the front.
                        XS1100SF
                        XS1100F
                          Yep, I agree. If the petcocks are on correctly then the front outlet is PRIME the rear is RES and ON. The petcocks can be switched as suggested, sound sliek that is what you have.
                          • 777jfk
                            • Jun 2009
                            • 9
                            • Lapeer, Mi
                            Petcocks and fast idle
                            Mine have the Prime toward the front. What way are they suppose to be?
                            Jerome
                              • 3189
                              My first thought was that possibly the vac lines to the carbs were switched and ya had vac opening the octy at the wrong time so the petcocks were not opening right. Now if ya checked all that stuff I am just reading in anticipation of the answers
