trouble getting xj to turn over
  • 84xj1100
    • Sep 2005
    • 47
    • Rockland Ontario Canada
    If you have located the problem that's great however that emergency kill switch if it's not used routinely will develop a resistance and eventually cause you grief.
    I would suggest that you give that switch a good cleaning to avoid any future potential probs........just a thought.
    "ride to be visible but pretend you're invisible"
    84xj1100
    82xj1100
    • nightpilot
      • Feb 2009
      • 87
      • Atlanta
      thanks for the thought, i guess you mean the rocker switch on the right handlebars. re the starter switch, i think it makes sense to bypass it with one or two switches because it seems like a weak system to begin with.
      re resistance, I noticed the main power wire that goes off the positive battery wire gets warm when the bike is on. I think that means resistance which cant be good and think it probably should have a heavier wire.
      jim
      82 XJ 1100
      98 Magna
      past bikes
      ST1100
      92 Harley FXR built
      85 XJ 700 (2)
      86 XJ 700X
        That can also be from resistance at a connector. The ignition switch and connector is one place that likes to go, as well as the ground connections. I usually clean and grease ALL my connections. I use dielectric grease on the power connectors, and anti-seize on all ground connections. The anti-seize is conductive, and the dielectric grease is not.
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          Redhead
          Originally posted by trbig
          No problem. Us XJ owners are the redheaded step-kids of the group.
          We want to be included.. but we're just.. you know... different!
          Hey .I resemble that remark ...
          XJ1100K
          Avon rubber
          MikesXS black coils
          Iridium plugs w/ 1k caps
          MikesXS front master
          Loud Horns (Stebel/Fiamm)
          Progressive fork springs
          CIBIE headlight reflector
          YICS Eliminator
