My toolbox does not have anything large enough to remove the locknuts off the rear swingarm. Does anybody know what size they are so I can go buy the right sized socket? Is the pivot bolt turned with an allen wrench?
I had no problems removing the 4 bolts that hold the driveshaft to the middle gear housing
However, I cannot figure out how the driveshaft and u-joint are supposed to be removed through the rear. They seem to large for the hole. What am I missing?
Finally, is the rubber boot supposed to be filled completely with grease, or is this mess a gift from the PO?
Thank you in advance for any and all assistance
