Carbs
  • gbsteph
    • Sep 2002
    • 4
    • Grand Prairie, Texas
    Carbs
    When setting carb float height, the book says measure from bowl gasket surface. Does that mean the surface where the gasket rests or from the gasket surface with the gasket in place? Also has anyone tried the clear tube method on a 78-79 model by adding a fitting with tube connection in place of drain plug? If so what would the fuel level be in the tube compared to Talbots pictures on his thread?
    Thanks for any input
    GB
  • sixtysix
    No XS but XSive as can be!
    • 1958
    • Central New York State
    It means the surface of the carb where the gasket sits. The gasket must be removed.
    Gary Granger
    • gbsteph
      • Sep 2002
      • 4
      carbs
      Thanks Gary. That's the way I have always done it but I was always curious.
      GB
