yamaha Xs100
  • kevinbarzotelli
    • 23
    • Fox River Grove, IL
    yamaha Xs100
    hi can anyone help im looking at a yamamha Xs100 and the guy who is sellling it told me that this model does not have a choke is this true? thanks Kev
  • foreda
    • 949
    • Southwest Louisiana
    Choke
    It is not technically a choke. It is a enriches the mixture, however it does have a handle just like a "real choke".
    78 XS1100E Standard
    Coca Cola Red
    Hooker Headers
    1979 XS1100 Special
    1980 XS Standard
    2006 Roadstar Warrior
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      This is what I posted on your other thread.
      Unless the bike has different carbs that what came from the factory, the 79 should have a lever on the left side of the carbs (left as you sit on the machine) that pulls a rod out on all 4 carbs activating the enrichening circuits. If there is no lever or rod then you are missing some parts.
      In a way the owner is right in that the XS1100 does not have a choke since the device does not close the airway through the carbs. It is more of an enrichener in that it adds more fuel on starting to acomplish the same end result.
      Mike Giroir
      79 XS-1100 Special
        It may not technically be a choke, but even Yamaha put the word "Choke" on the lever handle. The rubber thingy on the handle identifies it. (mine's bent over, where most aren't)
        • Crazcnuk
          • 2980
          • Hinton, AB, Canada
          Better tell him it's not supposed to be bent 90deg like that!
          The rubber end should point up, at just a slight angle away from the bike so you can get your thumb on it.
          '05 ST1300
          • lvrsnr
            • 114
            • Kelso, Washington
            the only other thing to keep in mind when using our fuel enrichment system is that if you open the throttle you lose the extra fuel, and can crank it a long long time without it starting. if you do that with a choke system you flood it badly.
            Alias Larry R in Kelso WA
            When in dought, punch it.
            XS1100LG Precious current
            XS1100SF Ruby gone to a better home
            KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
              I did!
              Thankfully, I just got a non-bent one that I'll be installing soon.
