Proper Voltage of XJ Oil Level Sensor?
  • kervey
    • Mar 2009
    • 4
    I am tracking down an issue with my oil light staying on, can someone please let me know what the correct output voltage for the XJ oil level sensor is? I am reading 3.5 to 4 volts when the motor is running. Thanks!
    82 XJ1100
    78 CB750F SS
  • randy
    • Dec 2003
    • 4521
    Might there be a test procedure in the shop manual? JAT.
    • kervey
      • Mar 2009
      • 4
      Figured it out
      I experiemented some today and determined that grounding out the sensor causes the oil warning light to go out. The 4 volts was supplied by the cluster. So basically this tells me I need replace or clean the oil sensor. Thanks for the help!
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        Careful, that sender only needs to be hand tight.
        XJ Computerized Monitor manual says
        "When installing the engine oil level sender, be sure to use your hand to tighten the bolt. If it is tightened using compressed air, sender malfunction may occur."
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
