Alright, I've got a bit of a mystery on my hands. A while ago, I took the carbs off and apart, cleaning them in an attempt to fix a sluggish idle/acceleration issue. I got them back on the bike and (despite a bit of popping) it ran rather well- certainly better than before.
Next day I go to check the carb sync. I hook everything up (syncing with a vacuum gauge), and notice that it's running quite rough and will die on anything less than half-choke. A quick check of exhaust pipe temperatures told me that (somehow) I managed to drop the first two cylinders.
Fast-forward one day later and (after swapping the fuel lines to see if it was a fuel-flow issue) now I can't get it to start a all.
As far as I can tell the petcocks are both fine- work like they should, and they aren't gummed up with anything. I know I'm getting a spark out of at least one cylinder (No. 1), and I have a feeling that the other one works as well.
The only thing I did the last day was to switch the left fuel line (which normally goes to carbs 3 and 4) to carbs 1 and 2 and the right fuel line to carbs 3 and 4. I think I'm going to switch it back tomorrow to see if it makes any difference whatsoever.
As a final note, when I went though the carbs I took everything apart EXCEPT for the mixture screws. I don't know how much difference this makes when it comes to dropping cylinders, but it's best to give all the info I can in a situation like this.
Does anyone have ANY idea what could be going on with this?
