Hello Folks: This is Dan again and I'm seeking pumping compression numbers
on the Elevens of fellow XS members for my data base. I'm looking for comparisons between the early ( 78-79 ) and the late (80-81-82) models and specifically those combinations that have the Wiseco 1179 or 1196 kit installed. It's also important to note which cam the bike has (early or Late), how many miles on the motor and if and how much the head has been cut (shaved). Of course if you have an after market cam that's very important too because the closing of the intake valve dramatically effects the pumping compression of the motor. The test should be done with a good battery, screw in type gage on a cold motor with the throttle wide open and the choke fully engaged (pulled open). The shop manual list 142 psi @ sea level as standard on all models with a plus or minus of 14 psi as acceptable. From what I've garnered from my own test, late Elevens with the short cams and about 30,000 miles on the clock seem to generate the most pumping compression but I don't have much data on the 78-79 models with mileage in the 30,000 mile range. Any information that anybody can throw me would be very much appreciated.
