front shocks
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    front shocks
    hey all,
    I am currently working on replacing the seals on my brothers 80G and the seals that he got are too small on the OD. The part(stamping) a 10.5-12. is this right? what is the correct part # i need? where can i get them?
    also is it normal(to an extent) for the springs to be worn out to the point of being 4 inches shorter than spec?
    thanks
    -Genius
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
    Standards use the 37X49X8 size. That one you mentioned is probably for a Special. I get mine from Dennis Kirk usually, but any company that sells fork seals should have them. No that's not normal spring wear. The springs for the Special are about 3.5 inches or so longer than the Standards.
    • geniusloerts
      • Jul 2007
      • 420
      the springs i mentioned are for a standard and not a special
      just out of curiousity what is the size of seals for specials?
      -Pod Filters
      -4-1 pipe
        37x48x10.5
