Electrical problem...
  • Sleeping
    • Jun 2009
    • 12
    Hello,
    I have a 81 XS1100 Midnight Special. I've had it for awhile now and I can't seem to figure out the electrical problem it's having and I could really use some help.
    Everything will work fine for a length of time, anywhere from a couple days to a month or so. Then after that I will start having to charge the battery every day or so to make it start or disconnect the headlight when I try to start it. It randomly seems bogged down shortly after I start it when it's having these starting problems and will shut off if I give it too much gas, if I let it run for a little bit that goes away. The battery is pretty much new and all the fuses seem to be in order.
    Any suggestions you have would be very much appreciated. Thank You.
    1981 XS1100L Midnight Special
  • dbeardslee
    • 4385
    • Maineville, OH
    My suggestion is start going through your electrical connections and make sure they're clean and have good continuity. Take your time and do it right. Pay particular attention to the connectors that live behind the fuseblock mounting plate. There's a relatively large white wire back there that likes to burn it's insulation off and will short out the whole works. If you see any connections that look like they've gotten hot replace them. Heat is generated by resistance and resistance comes from poor connections. Also, don't forget about the connectors in the headlight bucket - particularly the one that runs to the ignition switch. All the power to your coils runs through the handlebar kill switch, so cleaning that is beneficial as well (be careful if you take it apart - there are some very small springs and a tiny ball-bearing in there that will pop out when you take it apart). Z1 Enterprises has a nice selection of connectors. I would also put a digital multimeter on your connections at the TCI and make sure your pickup coils are OK, and I would test your ignition coils as well. Even if you've done the pickup coil wire fix, I just learned recently that the fix can 'wear out'.
    • Mighty Eleven
      • Apr 2009
      • 29
      • s.florida
      I just had the same problems and went over every wire and connection. My battery was only a few months old but had a short in it allready. Every thing is made in china. JAT.
        Hey there Sleeping,
        DB provided lots of good advice. You need to take a voltmeter and put it across the battery terminals, start the bike and test the voltage at idle, should be about 12 or hopefully a little higher, but then rev it to 2500 and recheck it, should be ~14.5 volts, if still only 12 volts, then the charging system isn't working properly. Do like DB said in checking and cleaning the connectors, especially the ones behind the fuseblock. Also remove the gastank, check/clean the connectors on the Reg/Rect unit. The R/R unit is very common problem to die and cause loss of charging much more so than the actual stator and windings.
        • Sleeping
          • Jun 2009
          • 12
          Thank You
          I'm going to try going over the wiring tomorrow. I'll let you know how it turns out. Here's hoping.
          • b.walker5
            • Feb 2009
            • 1745
            • Invercargill, New Zealand
            Just to add to everything above, if your alternator isnt charging, your rev counter will likely not be working, it runs off one winding of the 3 phase alternator. If it's flickering intermittantly, or not working at all, it's a fairly good clue that the windings plug (3 white wires) could be crook. If it's not flickering then check the regulator, as TC has suggested. Careful of how many extras you may be running, the alternators are weak as water and cant handle much extra load, I fried mine a few years back with some heated hand grips. I got it rewound and had it beefed up and now I could run a house off it.
            • dbeardslee
              • 4385
              • Maineville, OH
              Oregon Motorcycle Parts sells a replacement regulator/rectifier that puts out twice the amperage of the stocker, and provides full charging at 1200 rpms as opposed to the stocker's 2k rpms. I haven't tried it yet (but it's on the list), but it's supposed to be good if your running extra electrics. JAT
              • egleaves
                • May 2007
                • 441
                • Sacramento
                Keyword here is seem. I used to have intermittent electrical problems and one day it finally quit. First thing I checked was the fuses, but I moved on because they all seemed fine. On the advice of another member here (I can't remember who) I whipped out the multimeter and checked for continuity across the fuses and much to my amazement a fuse that seemed fine was in fact not. I replaced a fuse and was back on the road.
                I still had intermittent problems, though, so I did TC's fuse block upgrade and you might be surprised at how many little problems just "went away". Plus, it's much easier now to visually inspect a fuse.
                I know this, because Tyler knows this.
                1980 SG
                3J6 003509
                Kerker 4-1 (sans baffles)
                Fuse Block Upgrade
                Mike's XS Green Coils
                Pods w/Homemade Velocity Stacks
