Nutral switch
  • BIGTOMMY
    • Jun 2009
    • 1
    • N IDAHO
    Nutral switch
    WASHED THE BIKE AFTER A SHORT RIDE. AFTER WASHING STARTED IT UP , WITCH WAS FINE BUT WHEN I PUT TIN GEAR IT QUITS. CAN ROLE IT WITH CLUTCH IN SO ITS NOT HANGING UP. SAYS SOMETHING ABOUT A NUTRAL SWITCH IN THE BOOK BUT THATS IT. ANY IDEAS ITS A 79 SF. HAVE HAD PROBLEMS OVER THE YEARS BUT THIS IS A NEW ONE. THANKS BIGTOMMY
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Neutral switch in the 79's is for the light only, you can actually start the bike in gear if you want. Did you try more then once? Maybe the clutch was a bit stuck the first time and stalled it. Also, please turn your caps lock off
    1979 xs1100 Special -
    My Bike:
    [link is broken]
      As stated, in all except maybe the XJ, the nuetral switch just lights the light. It does nothing to prevent starting, and none except maybe the XJ have a kickstand switch so that should not be doing it.
      Souns like maybe your bike got a case of the dampa$$ from the washdown. Maybe let it dry out and try again. If it runs fine then, probably moisture got into the ignition system and made your spark weak that it would not support load till it dried out. JAT
      • Dragon Tamer
        XStremely XSive(Deceased)
        • Sep 2006
        • 426
        • Half way between Chili and Winter Wisconsin.
        Oh Yah Tommy
        XS11's are NOT aquatic animals.Let it dry out and it will probably be OK.
        The Old Tamer
        _________________________
        1979 XS1100SF (The Fire Dragon)
        1982 650 Maxim (The Little Dragon)
        another '82 650 Maxim (Parts Dragon)
        1981 XS1100SH (The Black Dragon)
        If there are more than three bolts holding it on there, it is most likely a very important part!
          • 8930
          I agree on the damp wires. I have the same problem when washing the bike sometimes.
          • MindWebs
            • May 2009
            • 431
            • Baldwin, WI
            wet wires
            if you want to avoid this condition it the future, go thouth your wiring and use dieelectric grease on the high current wires and dieelectric spray on the low current wiring.
            Be carful!! dieelectric grease can limit current flow on low current wiring!!!!
            (screwed up a 97 chevy really bad with that)
            dieelectric spray is "weak" enough to protect your low draw from water
            give it a shot and you'll have a bit better luck playing in the water.
            • clcorbin
              • Jan 2010
              • 495
              • Albuquerque, NM
              It REALLY shouldn't matter if the CONNECTOR is making good connection. Those contacts should almost dig into each other and they WILL cut through dielectric grease no problem. Of course, if the contacts are loose, then all bets are off. But I would rather replace a crappy connector...
              -- Clint
              • Barnfresh
                • Mar 2009
                • 160
                • Abilene, TX
                Hey BigTommy - posted this about a year ago...
                Long story short - when a connector that carries the tci wires gets wet grounds through the neutral light wire and hoses the ignition circuits.
                Most disconnect the neutral switch under the shifter, but here is a permanent fix.
                When the horse is dead, dismount.
                Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
                  This thread is almost 4 years old......
                  • clcorbin
                    • Jan 2010
                    • 495
                    • Albuquerque, NM
                    My fault! I used the search.....
                    -- Clint
