OK. Don't laugh me off of the site... but... to fill the front and rear brake fluid cylinders, do you just take the top cover off and fill or is there a better way?
If your referring to the master cylinders, yes you fill them by removing the covers and rubber diaphragms under the covers. Do not over fill and keep in mind that brake fluid will damage paint. Use DOT 3 fluid.
Rob
