My new 1.1
  • XSrunner
    • Feb 2008
    • 97
    • Batemans Bay AUSTRALIA
    Hi Lou thanks for the comment This bike is a AMERICAN IMPORT it came to australia with the original owner in 1980 he's now 73yrs old and can't ride anymore i got it in PICTON 18mths ago. When you get yours running don't forget to check the grease in the splines in the final drive (undo the four bolt don't just use the grease nipple) mine was empty
    JOHN'O
    Xs1100E 1978
    American Import Cruiser
    • beemeerr11
      • Jun 2009
      • 39
      • Greenleigh Australia
      Thanks for the advice, I can't seem to nail how much oil is used in the transmission, all the talk is about having a measuring tool?
      So in the rear drive shaft/final drive, is there no oil???
      Went to photobuckets and downloaded 2 photos, but I wqas stuffed if I could work out how to get them on this site...
      Cheers
      Lou
      81 1.1RH
        There is a tech tip on making the tool, gives the measurements. I just used a piece of paper rolled up and used it as a dipstick to measure the depth to match those given in how to make the tool.
        The final drive gets the same hypoid oil as the middle drive. Most use synthetic for these two drives. One end of the tool in the "how to" is to measure the final drive oil.
        Once you have pics on photobucket, hover on pic and you will get a drop down with links under it, find the IMG link and copy it from there and paste it directly into your post.
        • beemeerr11
          • Jun 2009
          • 39
          Thanks for that advise, what do you mean by the IMG link?
          Lou
          81 1.1
            Once you load the pic in photobucket, when you hover your mouse over the picture a number of "links" show up under the picture. I do not recall what all are there but one says "IMG". Highlight it, then hit control and C for copy. Com here to your post, hit return to be on a blank line and hit control V for paste and hit return to finish the line. when you post the picture will appear. Once your on photobucket it will be very clear and easy.
            • beemeerr11
              • Jun 2009
              • 39
              My new 1.1
              Here is what I have to start with, lets see how it turns out.
              Cheers
              Lou
              81 1.1
                Very nice!!! Great looking bike to start from!
                • XSrunner
                  • Feb 2008
                  • 97
                  HI LOU nice looking bike I bet an old bloke owned it (mudflap on the front)ha!! you'll love it when you get it going. do you have any workshop manuals to help you out.
                  JOHN'O
                  Xs1100E 1978
                  • beemeerr11
                    • Jun 2009
                    • 39
                    Hi XSrunner,
                    The guy I got it from was older"" built like a brick sh%t house, bald head, with a Merv Hughes moe, but he never touched the bike, as he wanted to restore it, but things went pair shaped in the relationship, when I had a look at it, his garage was full of packed boxes, as he was moving out, hence the good price.
                    I down loaded a PDF and rember seeing something about 4.5 litre oil changes, I have alot to learn about these bikes, but I was under the impression that the motors are basically the same e.g. all hold 3 litres of oil??? I've pulled more apart tonight and did a compression test, I'm liking mucking around with this bike, and commenting as I go, as to the things I could do to it?
                    Cheers
                    Lou
                    81 1.1
                      • 5062
                      The oil capacity is marked near the filler hole. It says 3000cc if I remember correctly. I know that 4 quarts will fill it just a little too full after a new filter is installed.
                      • petejw
                        • 2269
                        • sydney australia
                        Nice original bike,
                        thatll do up nicely, pity your not closer
                        i couldve given you a hand.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • Shappers
                          • Sep 2006
                          • 158
                          • Helsinki, Finland
                          Hi XSrunner,
                          Cheers
                          Lou
                          81 1.1
                          Hi Lou,
                          Very nice bike "Our" bikes take a little more oil than the US versions as we have the oil cooler installed, capacities are 3.0 litres for an oil change, 3.7 liters including a filter and 4.2 litres on a dry engine..
                          When you need to look at the wiring, HERE is a link to a colour wiring diagram. I made it for the Sport model but it also identical to the Aussie RH model.
                          Have fun,
                          Shappers.
                          '84 Sport
                          • beemeerr11
                            • Jun 2009
                            • 39
                            Originally posted by Shappers
                            Hi Lou,
                            Have fun,
                            Shappers.
                            Hey Shapper,
                            Thanks for the info, I drained the oil and got nearley 6 litres out of it, but could have been due to fuel from the carbs overflowing into the crank, I'm surprised that the bike has a low fuel warning light, but doesn't have a low voltage/charge light indicator???
                            Cheers
                            Lou
                            81 1.1
                            • beemeerr11
                              • Jun 2009
                              • 39
                              Here is the end result.
                              here is how the bike turned out, this is on it's first run.
                              Lou 81RH (Aus)
                                Very slick looking machine!! Nice Job!!
