So I just got done checking valve lash and timing.
Here are a couple pics of timing as it sits.
So it looks like maybe timing jumped?
I am getting air coming back through #1 carb and the plug fouls quickly.Also producing some popping.
Should I re-time the cams or should I be suspecting a bent valve?
Thanks. Rick
Thanks. Rick
). Then check where your pointer is pointing.
