My experience so far with BS34 III's (what the 80's have on them generally) is that the o-ring under the washer and spring on the mixture screw is critically important, and if it's shot (almost guaranteed at this age) you will have a really hard time getting a good idle. You can get the o-rings and all from MikesXS as the 80-82 650's use the same carbs as we do with the same mixture screw assembly.
PS: from what I have seen, all the 80 XS's use the same carbs, and share the same problems with them. Make sure to replace ALL the rubber parts in there, or IMHO you WILL have problems down the road if not right away.
