They came off of an 80 XS1100G, so the do fit. That is why the confusion, I assumed they were early 80 Yamaha Mikunis.
They are close enough to pass themseleves off as Yamaha, but there are a few slight differences.
1) Diaphragm springs are much smaller.
2) Lids have smaller guide for the smaller springs
3) no detent balls/springs on the choke rod, but an extra spring
4)Same size slides, but different circlip system for needle retention.
5) shorter, fatter needles
6) X-6 tubes
7) Float valve retention clip has an arm to limit float drop (no clips on the float needle)
8) Float bowl drain screws have phillips screwdriver capability, and smaller threads.
Other than that they are the same BS34's we all know and love, sort of.
From my reading, it looks like Suzuki used these for most (all?) GS models after 1980. They are, however, tuned for each specific bike. So, in order to get close on the tuning I need to find the specs for these carbs if they were on a GS1000 or preferably a GS1100.
From there it would be the usual trial amd error.
I don't know if I could just set them up as using all the XS11 parts for this particular style of carb (ie: early 80's transition)
I have 42.5 pilots, 185 air, and stock needle/tube sets, but I would have to order 137.5 (and larger) mains.
6) X-6 tubes
