My plugs are always black. I am also concerned that I am getting about 24MPG as well.
Since I had to remove the fuel tank today to fix a leak I decided to clean the carbs as well. With the carbs off I thought I would try to compensate for the black plugs (Rich condition?) by adjusting the floats. I found the floats set at 25.4mm and lowered them (lowered as it sits upside down on the bench) to 24mm. This seemed to help as after a short ride around the block (5 miles) the plugs were clean on my return.
I was reading many posts today on adjusting the carbs and was rather confused over what effect lowering or raising the floats will have? I thought that by dropping the floats from 25 to 24 that I made the mixture more lean. (Less fuel? to air) and that raising the floats say from 25 to 26 would add more fuel to the mixture making it rich.
Current jets are
137.5 main
45 Pilot
210 Air pilot?
So is my head screwed on right? Floats up rich, floats down lean?
Current jets are
137.5 main
45 Pilot
210 Air pilot?
Terry
