Accel Coils
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    Accel Coils
    Hey Guys,
    Finally mounted my coils. The bike is an 81' Special. I believe all I have have to do is add the wiring now. Is the orientation going to work.
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    Does it matter on the wiring which wire goes to which terminal. There is no marking on the coils. I would like to just cut the pig tail harness from the old coils and add the terminal ends from the Accel kit and connect them.
    I know I read it somewhere just can't find it.
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
      • 2117
      Looks very clean in there!
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        This is the same set up I have on my Hop Up bike, Tight fit eh. Installation instructions say it makes no difference which way they are wired and that is the case.
        However, I made the two posts common and the out side posts left / right. I sort of hooked them up like stock after deciding that the 2 center posts would be red.
        NOTE: do not over tighten the terminal nuts and do not allow the wrench to contact the brackets causing a prying action when installing the nuts or you can very easily break off a post. Don't ask me how I know.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • gene
          • Mar 2009
          • 267
          • Weston, Fla.
          Rob
          Ok, sounds good. I guess I wanted to double check. Thanks for the heads up on the posts.
          Gene (Florida)
          1980 XS1100SG
          Accel Coils
          4-1 Jardine Exhaust
