slow to return to idle
  • drooker56
    • Mar 2009
    • 128
    • Grand Rapids MI
    I have her running better than ever before. I still want to upgrade coils but have an idle problem to solve first. When I start the bike it idles fine around 1000rpms maybe a little under, she sounds great. once I ride for a while when I come to a stop the idle sits and hovers around 3000rpms for almost a minute before it returns. I checked my carb boots and other vacume lines, I can't find a leak. I am wondering about a float being stuck or maybe too high, what do you think? I don't really think one si stuck cause I had that before and in idle it spilled fuel out of the pods. She is almost perfect I just need this one last thing. Could it be a sync problem? I am going to try to get sticks from a guy at work anyway but he hasn't been in in a few days. Any ideas?
    1979 Standard F, At least I think it is.
    It IS the sync. You cannot really tell what is wrong until you have everything set up properly. All I can say is live with it UNTIL you have it synced. I'll bet the problem goes away.
    • drooker56
      • Mar 2009
      • 128
      • Grand Rapids MI
      thanks I will try to get the sticks.
      • Bigfoot
        XS-XJ GURU
        • Sep 2005
        • 1422
        • Kansas City, Missouri
        I agree with DiverRay. Mine had the same problem until we sync'd. Then it went away.
        Harry
        '79 Standard
        '82 XJ1100
        '84 FJ1100
        Acta Non Verba
        • tw1980
          • Apr 2009
          • 662
          • Bend OR
          Yeah like the guys said... But I had the same problem.Not only did I have to sync the carbs I had to adjust the idle mixture as well.In fact the idle mixture is what fixed the problem but I had to get the carbs synced first.I don't know if this applies to your bike.It happened to mine after I installed the @#$%& dyno jet mod kits. Terry
          1980 special (Phyllis)
          • psycoreefer
            • Feb 2008
            • 1557
            • Minden, NV
            Hey, I can borrow a set of gauges if your having a hard time finding some. My father in law has some that are brand new, and I have a single gauge although doing it that way is kind of a pain. Let me know....
            1979 xs1100 Special -
            My Bike:
            [link is broken]
            • drooker56
              • Mar 2009
              • 128
              • Grand Rapids MI
              Brian, that would be awsome! I have a cheap single gauge I got from Harbor Freight and I had to make a pvc baffle for it and the needle still bounces between a 5lb range. If you have a set i would love to borrow them or get together maybe have a beer and work on bikes let me know. I may or may not have to work this weekend, I find out tonight. If I don't I'll give you a call.
              • psycoreefer
                • Feb 2008
                • 1557
                • Minden, NV
                Don, I'm going out to the in-laws house today so I'll grab his gauges while I'm there. Saturday we are planning to go to that arts festival downtown but I can probably sneak away for a couple hours if saturday works best for you. Sunday we are probably doing church in the morning but anytime after like 12:30 would be cool. Give me a call.....
                My Bike:
                [link is broken]
