#4 cylinder
I just bought my 81 1100 Midnight Special. It was minutes away from reaching boat anchor status. Ive gone through the bike lubing and freeing up every moving part and changing all the fluids. I was having a problem with #4 cylinder being dead, actually still do. I found the rings were stuck and I was losing compression when it got hot. I fixed that with a few doses of seafoam. I went through the carbs and when i put them back and went to check the air/fuel mixture screw setting, i found #4 was stuck and ended up stripping the head. I believe this is common because of the screw being on top of the carb and the tilt of the bike exposes #4 to run off from the tank when the caps are missing or leaking.
I am waiting for a new part to come in this week. The bike runs a little rough at idle and through 5000 rpm but comes alive from 1/4 throttle up through to redline. At idle, I can pull the #4 plug wire with no change and i can pull the vacuum cap off with now change.When I pull the sprak plug out it looks wet. If I spray any cumbustible fluid in the vacuum port, the idle smoothes out. From what Ive read the mixture screw controls the air that goes in at idle because its on the back side of the carb. Something just doesnt make sense. Does anyone see anything Wrong with what Ive said so far?
