lit up!
  • GARTHXS
    • 1631
    • Seattle
    lit up!
    So I replaced the headlight on the 78 which has a special headlight bucket , It had a sealed beam and I got a halogen lens and bulb for 23 bucks off fleabay man what a difference I can actually see at night , and forget about the bright it lights up every thing . it has a plain bulb in there and the color is good . the weirdest thing is when you hold your hand in front of the beam you can feel the heat even @ 12'' out, the lens is not that hot but the beam is like a laser!!
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    Yah Oui!
    I changed mine out on the fairing, I have a Vetter Windjammer II.
    It had a sealed beam like you had, really terrible.
    Went with a Cibie reflector with Osram 65/80W H4.
    I ran 10 Ga wires(POS and GND) with Heavy Duty relays.
    For a single, this thing throws a lot of fire out there. It is such a difference.
    Don't need no AUX lights!
    XS1100SF
    XS1100F
