82 XJ1100 maxim Shock Pressure
  • Filter
  • 82 XJ1100 maxim Shock Pressure
    Hey guys, I have some 82 xj shocks that need to be aired up.... how much PSI do I put in them???
    Austin Ingalls
    MIDNIGHT FURY
    1979 XS1100 Special [Full Restore Project]
    XJ maxim rear air shocks
    KERKER 4-into-1 exhaust
    Pod Filters
    Money pit.......
    BLACKED OUT
  • #2
    I believe 55 psi is the max. You would need to experiment to find what pressure your butt likes the most.
    • #3
      57 psi max in the rear shocks
      17 psi max in the front shocks.
      Be careful if you fill them with a gas station air compressor, the volume of air the shocks hold is very minimal and you can blow the seals out in a heart beat.
      The suggested pressures for a solo rider is 6 psi in the front and 14 psi in the rear.
      HTH
      Paul
      Paul
      1983 XJ1100 Maxim
      1979 XS1100 Standard
      1980 XS1100 Special
