I've been going over all the posts related to piston rings to try and help me decide my next step. I had a valve job done at a local engine shop (not sure if I should post the name of the shop here) and at the same time I brought the cylinders and pistons in for them to evaluate. They said the pistons should run fine and the cylinders where good... I had done a light deglazing myself.
My original rings are not usable... well actually 3 of the 4 sets are not. So I'm looking at buying standard rings which seem to be around $60.00 per piston, ouch... Or is it OK to use 1st oversize rings which seem to be available for 39.00 for 4 pistons? The tech at the engine shop didn't like that idea however I thought I read a thread where someone felt that it would work but the break-in period would be longer. Has anyone actually used 1st over piston rings in a standard bore? And I assume you need to grind the ends to fit the rings into the bore to end up with the proper gap clearance.
'78 XS11 E Restoration
