xj 1100 maxim
  • bjørn.norway
    • Feb 2003
    • 3
    xj 1100 maxim
    hey... After five days with trouble with overflowing carburators, now the spark plugs gone... Is this a illnes the bike got ? So much trouble for so little...!!!!!
  • Mike Hart
    • 1025
    • Seattle, Washington
    Your plugs are fouled? You probably have gas in your crankcase oil. Not good. Make sure the float valves work properly before you change the oil and run the bike again.
    Mike * Seattle * 82 F'n'XJ1100 *
    • bjørn.norway
      • Feb 2003
      • 3
      82 1100 maxim
      Hey Mike... Thanks for helping me.... Today i changed the oil (there was much fuel in there) changed the filter.. Then ill stopped the leak.. Id seen now from your tip of the float should be at 20 ? I'll dont know what they'll be now... When ill started the engine, it seem to work on two of four cyl. I'll cheked the sparks, and seen the two on the right side didn't work... Can they be damaged of all the fuel problems ?
      • Mike Hart
        • 1025
        Glad you are making progress, Bjorn. I had trouble with plugs that had gotten fouled from fuel in the oil, even cleaning them didn't help, try new ones. Since the two bad ones are on the same side, that is not an electrical problem.
