carb question
+ More Options
Posts
  • EXXXCESS
    • Mar 2009
    • 46
    • greene county ga
    carb question
    I have an issue with my bike reving up on its own can any one explain why this might be happening. It starts out in one carb the number 2 and then all of them follow any help would be appreciated.
    79 XS 1100 Special
  • tarzan
    • 1700
    • Chandler,Az.
    If your carbs are out of sync they will do that.A vacuum leak could do it too.
    Does this happen only at idle?
    80 SG XS1100
    14 Victory Cross Country
    • EXXXCESS
      • Mar 2009
      • 46
      • greene county ga
      Yes it will do it at idle and when it revs up I can blip the throttle and it won't rev back down.
      79 XS 1100 Special
      • boyat68
        • Oct 2007
        • 358
        • Virginia
        As Tarzan said,"This is a case of synchronizing the carbs correctly." One carb's vacuum will cause the others to follow. You have to get each of the carbs to be near or exact to the # 3 carb as that carb has no synchronizing screw and the other carburetors must be set to mimic the no. 3. Once this is done and the idle re-set, then the bike will operate correctly.
        • SFerinTEXAS
          • Jun 2006
          • 876
          Can you enlighten me as to how you came to the conclusion that it starts with #2 ? BTW I also agree its a sync problem .
          79SF
          XJ11
          78E
