How's it going?
My story is the same as many others on this site (I know- I searched)- first-time bike owner, bought it from some guy who had it sitting in a barn for at least a couple of years, sadly with gas still in it. It ran (albiet sluggishly), but trying to get it to do something other than idle has been an... adventure? A pain? Pick your adjective.
The bike in question is a 1980 XS1100 Standard. Long story short, I can get it started, and I can get it idling. However, it only idles at half-choke, any less and it dies. In addition, even after warming up for 20-25 minutes, you can't even THINK about touching the throttle at all, unless you want the engine to die, of course.
When it IS running, there's quite a bit of popping/backfiring, coming from cylinders 3 + 4 (the two on the right side, when viewed from the back). I'm not sure if this is an issue connected with the larger problem, or a side effect of running on half-choke.
Now, I've seen countless other threads about similar problems, all with the same answer- "Crack open the carbs and clean them." I guess I'm trying to avoid this at all possible. I'm not what you'd call mechanically inclined- when I look at an engine, I'm not sure what half the stuff does (even AFTER reading the various FAQs on the subject on this site).
I guess what worries me most is the fine-tuning/syncing when you put them back in. No clue how to do this, what to look out for, WHY to do it, and how not to screw it up.
So, what do you think? Is this a problem that can be corrected without resorting to tearing apart a precision-mechanical instrument, or am I going to have to bite the bullet? (If so, be prepared for deluge of further questions!)
Thanks in advance.
(I DO have a camera, and know how to use THAT, so if anyone needs further photos/information, PLEASE let me know.)
Thanks in advance.
There are plenty of folks here who have been in exactly the same position you are right now, and can now give expert advice without even having to think about it.
It might actually be important as to how?? Did you try sucking on the vacuum hose that goes from one of the carb intake port to the petcock? If so, then the petcock diaphragm may be damaged allowing fuel to leak into the vacuum hose?
