Sparkplug wire trim
  • kevxs
    • Apr 2009
    • 353
    • toronto
    Sparkplug wire trim
    "remove the sparkplug cap, trim it back about 1/4 inch and reattach"
    Hi guys, I want to try the above fix I found in the forums on my 79SF. However I can't figure out how to remove the wires from the caps, any suggestions?
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
  • randy
    • Dec 2003
    • 4521
    The caps unscrew from the wire. IF YOU HAVE THE STOCK COILS.
    • kevxs
      • Apr 2009
      • 353
      • toronto
      yeah i'm all stock, i'm having problems with cyl 4 not firing as much as it should, i'm hoping this will be a quick fix and I dont have to do the mikesXS coil upgrade. Had some major misfiring yesterday after a visit to the car wash, i'm thinking my wires might be bad and the coil upgrade is required.
      Green Dyna Coils
      1973 CB100
      kevXS
        • 2117
        Or the wires are wet from the car wash.There is wire dryer available in stores.
        • randy
          • Dec 2003
          • 4521
          When I started my restoration, the wires were so dried they crumbled to pieces. I did the 'new wires in old coils fix'. Been running fine for 5 yrs now..oh, I probably jinxed it right there...
            • 2117
            Randy-i did that mod too and like it-but i cant find the angled boots without crimping(need some molded ones).Maybe i have not looked enough.
            • randy
              • Dec 2003
              • 4521
              I used the 90 degree caps, the plugs are angled anyway. Enough of an angle. I did use a longer cap for 2&3. IIRC, I got them from CRC2online. Look in "ELECTRICAL' then "COILS" and then "COIL ACCESSORIES"
