loss of power / backfire
  • 1980andy1100
    • Jun 2008
    • 3
    • Chicagoland
    Hey fellows, its been a while, which means I've had a couple good riding seasons, but the bike has been acting up oddly lately.
    I have ridden it a couple successful times this year. My last was a few weeks ago when out of the blue I started feeling a power loss, which kinda seemed to come and go as I rode. Eventually it started backfiring on me and was really hard to keep running. I ended up making it home after it started backfiring about 15 miles.... It was incredibly loud almost like a shotgun and the guy I was riding with said at times I was shooting 6" flames out of the tail pipes.
    I pulled the plugs... I believe it was cylinders 1 and 3 were very black, however all the plugs are in good shape. After simply cleaning them it seemed to ride fine again. I was then out of town for a couple weeks. It was real rough starting yesterday and I had to keep the choke on a lot longer then normal. I didn't actually ride it because I am pretty sure it will still do the same crap. I believe I am having an issue with the ignition, possibly timing, however I am not sure what to start with.
    Any ideas?
    Thanks
    Andy
    The most common thing I have read of is the pick up coil wires. Look in the tech tips. ITs the first thing I thought of when reading your description of the problem.
    • scalded dog
      • 458
      ...pic-up coils, also, how long has it been since you cleaned the carbs?. Later 'Dog
      • dbeardslee
        • 4385
        • Maineville, OH
        How long has the gas been in the tank? I'd try some seafoam before I did anything, as the problem seems to be associated with the bike sitting. If the gas has been in there a long time you might try draining the tank and refilling with fresh fuel. If you suspect your pickup coils you can test them easily with a multitester, but I'd check the dumb stuff first.
