Hoping for the best
Hey Silent,
As you may know, standard compression for these engines is around 140 to 145. But you need to check it with a warm engine, all plugs out, and the throttle wide open. Regardless, as long as your compression is within 10% between cylinders, which your's is, you should be OK. Particularly if you didn't follow the previous guidelines.
But without any information about the condition of your plugs and other behavioral factors, it's hard to assess if its the seals or something else.
Oil in the air box
Oil in the air box
As some of you know, I'm resurrecting a '79 Special. I finally got the bike out for a test ride this evening, and she's ruining OK, but I'm getting engine oil dripping out of the air box. The bikes been sitting for at least 5 years. Compression numbers are 115 118 105 100. Smoke out of the right pipe on acceleration, smoke out of the left pipe all the time, and more so under load. It's a white smoke. Started her up to move her in the back again and was a bit hesitant to start, and ran a bit rough for a min or two then cleared up.
The only thing I can come up with is either bad rings or bad valve guide seals. I'm running low on ideas, and I don't want to have to pull the engine.Tags: None
Leave a comment:
