plugs for XJ1100
  • nightpilot
    • Feb 2009
    • 87
    • Atlanta
    plugs for XJ1100
    It seems I can find out almost anything about an XS but as usual I am having trouble finding much about my 82 XJ11 that I am reconditioning. It came with 3 BPR8ES plugs and and one champ RN9YC plug. I have some other RN9YC plugs if those will work. Niether of these plugs are listed for the XS. The xj is a yics motor and I am not sure if its requirements for plugs are different than the xs. Help.
    82 XJ 1100
    98 Magna
    past bikes
    ST1100
    92 Harley FXR built
    85 XJ 700 (2)
    86 XJ 700X
    The correct plugs for the XJ motor is BP6ES (NGK), according to the Yamaha service manual. Same ones the XS's use.
    • nightpilot
      • Feb 2009
      • 87
      • Atlanta
      plugs and drive
      thanks for the info, has the 750 drive increased your mileage.
      82 XJ 1100
      98 Magna
      past bikes
      ST1100
      92 Harley FXR built
      85 XJ 700 (2)
      86 XJ 700X
        For highway cruising, for sure. For around town, 'bout the same as the 11 drive.
        • dbeardslee
          • 4385
          • Maineville, OH
          I run the NGK bpr6eix iridium plugs. They're expensive - about $7 a pop - but they're the best plugs I've found - as close to foul-proof as a plug gets. They work particularly well with hotter coils, and they come gapped at .035", so they're perfect with HO coils. You're not supposed to mess with the gap on them as the post can break easily, so for stock coils they may be a little to far open. You can change the gap (.032" for stock coils), but you have to be VERY careful.
