ok my lights grrrr!!!
  • easton04
    • May 2009
    • 3
    • rockland conunty new york
    heres the new skinny, i have no turn signals. they work on the flash/hazards mode but dont work any other way. i have read some posts about the relays and turning them and having one prong left out in the open. no dice. is there away to run all new wires and a new relay and tap in to the handlebar switch. or am i pissing into the wind. any help would be great the stats on my paper wait i mean bike is a 1980 XS 1100S.
    1980 xs 1100S in boxes
    Gotta Love It!
    Gill
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    Hey Easton do the lights illuminate but not flash or do they not turn on at all? Welcome to the sight! Terry
    1980 special (Phyllis)
    • Crazcnuk
      • 2980
      • Hinton, AB, Canada
      The 4-way lights and the signal lights use two seperate flashers. The hazard flasher is under the seat, while the signal flasher is under the right sidecover.
      You can swap the two flashers to see if it is the signal flasher that is bad/missing.
      '05 ST1300
        • 2117
        The flasher that is under the seat once in awhile comes up on E-bay or PM Andreas Weiss as he might have them.I snagged a brand new one on E-bay several weeks ago.
          Hey Easton,
          As has been stated, the Emergency 4 way flashers use a separate circuit and flasher, a simple 2 prong unit. Your OEM flasher for the turn signals may have gone bad? Take the 2 prong out of the Emergency plug, and plug it into the turn signals plug, you may have to try it 1 of 2 ways, but IF it doesn't work either way, then you'll need to get into the left handlebar switch assembly, they get corroded, wires get unsoldered, etc.!!!
