Wow, I don't believe I have seen nastier looking forkseals and murky fork oil that is less than a year old... I changed my forkseals this afternoon, thinking that it would be a quick 2-3 hour task...6 hours later I am done!
Here's mah tip:
Trouble removing pesky stuck in 20+ year old fork seals? Forget about that screwdriver, pick up a cheap tire iron! It took me 45 minute of swearing and trying not to gouge up my tube before I decided to try something else.
Well, that something else was a tire iron and took about 10 seconds to remove the rest of the seal. On #2 fork, took about 5 seconds to pop out.
What I did was put the tip of the tire iron in the middle of the fork seal, flip it all upside down so that the iron and part of the tube resited on the ground and made like a big lever.
Here's mah tip:
