Rear Suspension is Dead
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Hiya fellas So my rear suspension has finally taken a dump I am looking into getting the ones they have at mikesxs.com. The measurements i took for the ones i have on now are not very precise they are about 13 1/2 eye to eye. Would this one be the correct fit? For the measurement they list, is that measured at the highest setting or lowest setting?
    Part #06-3601
    Shock Absorber Set - (Monza Traditional) for 1974-84 XS/TX650's -Dual Progress-
    ive wound Chrome Springs & Long Black top shroud with black shock body.
    13 3/16" (335mm.) eye to eye., Includes preload wrench & set of eye rubbers.
    I found some of the posts that you guys have used mikesxs.com rear suspensions even though they are for a lighter bike & it all turned out ok. Couldn't find any info on what size you guys are using though.
    Thanks for listening guys!
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    Eye to eye free length with the bikes rear wheel off the ground. Spring preload does not change the eye to eye length.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
      The measurement listed is eye to eye fully extended. You could put any length on you want, lower the measurement, the lower the bike will sit.
        Hey Korr,
        The stock length according to the Partsnmore ones which are the only ones they offer for the XS11 is 12 3/4", part #06-3607.
        However, as has been stated, you can adjust this IF you want to change the seat height a little bit, to make it easier to flatfoot it, etc.!
        • GARTHXS
          • 1631
          • Seattle
          partsnmore
          I have two sets of these and they seem to work fine
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
          • Korr
            • Jul 2008
            • 293
            • Torrance, CA
            Awesome thanks for the replies guys! I will go with the stock size you listed.
            partsnmore is a few bucks less and it's the same part #
            Tkat Fork Brace
            On Hold
