Pods in place of Airbox - '78 XS11
  • XS_CAFE_11
    • Sep 2008
    • 7
    • Normal,IL
    I have decided that the look of Pods would be great on my bike - after tackling some Carb issues I am now wondering what all needs to be done to properly install the pods.
    The other question is what to do with the crankcase breather tube and also the two exhaust tubes from the carbs...not sure what to do with these things?
    Any help is appreciated - I am very new to this.
    '78 XS1100
    Air Pod Mod
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    If you search pods, you'll get plenty of info.
    The crankcase breather can be capped with a filter and the carb "exhaust tubes" as you refer to them are the floatbowl vents and can also be capped with air filters.
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
