Removed clutch cover
  • Thee_oddball
    • Apr 2009
    • 87
    Clutch basket off...bad news (pics)
    I took the clutch basket off this afternoon, I found the locking washer easy to bend back (and reuse in future) but I found that i did not have a socket for it (thought it was a 19mm it is bigger than a 22mm apparently..i was about to gice up and head to the store for a bigger socket set when i (to my horror) found it was on finger tighter , now that aside i was trying to figure out where the big washer went....well i came to the conclusion that it sit in the bottom of the basket , please correct me if i am wrong, what i found next put an end to todays activity's (see pic)
    I am guessing one of 2 things happened to crack that gear A: the basket was slammed into it during reinstallation or B: it happened when i popped it into gear a few times trying to break the clutch lose .
    anyone have a spare one they can sell me?? please PM
    this is where the washer was sitting originally
    does anyone know what caused this on the basket and should i get another basket?
    thnx for any help guys
    1982 XJ1100J MAX ,25.000 miles
      Not sure who worked on the clutch before you, but sounds like they didn't pay much attention to detail when they took it apart. The small gear you show... though I can't see the crack, if there is one, that little gear is pretty important. It gets driven from the teeth on the back of your clutch basket and spins that sprocket it is meshing with in your pic... which just happens to be your oil pump gear. I'm sure I have a couple of those gears laying around. PM me your address and I'll try to get one sent to you early next week.
      When installing your clutch basket on, sometimes it is very tough to get everything lined back up correctly and get the basket to fully seat. This may have caused someone to try forcing it on. Hard to imagine they forced it hard enough to crack a hardened gear.. but I've heard of worse.
      As for the "gouge" in the clutch boss itself.. I've seen several like that. I think it's just a blem from the manufacturing process. I have one that looks just like that that I ran for quite a while with no problems.
      • Thee_oddball
        • Apr 2009
        • 87
        thnx Tod, the washer in the wrong place the nut on hand tight ...some one Definitely! not pay attention when they put it back together, the cracked gear has spurs and rough edges along with the crack PM sent thnx again
          No problem... How did the discs look?
          • Thee_oddball
            • Apr 2009
            • 87
            #35
            Have not looked at them yet...going to get a tool to measure the thickness
              • 7831
              As long as you are in there, replace the clutch springs. They can be had online for about $20 or less. After almost 30 years, I KNOW they will NOT hold under stress!
                Check a local shop for the springs first. Mine (Local shop) is usually high priced, but they sell some good heavy duty springs for $16. Usually on lesser priced stuff like that, it's better to spend a couple extra bucks at your local place. It may be a couple extra bucks, but you won't have shipping charges, and if you ever need a favor like shim swaps or something.. they will be way more apt to let you swap for free than some guy off the street that doesn't spend any money there.
                • Thee_oddball
                  • Apr 2009
                  • 87
                  #38
                  the springs I took out have a....blue coating on half of the spring...does that mean they are new springs or is that an OEM coating? should i even bother to see if they are in tolerance levels per the manual?
                  thnx again
                    #39
                    IMHO, you've gone through all this to get that far, even if its $20, that is cheap compared to pulling all of this open again. Besides, given everything else the PO did, would you trust he put the right springs in?
                    • Thee_oddball
                      • Apr 2009
                      • 87
                      #40
                      rgr, understood,
