Things are going well with the EFI mod. However, the GSX-R throttle bodies have this small cable fitting that spins a little cam plate around that slightly opens the throttle. This is the "Choke" cable on the GSX-R. What I have found is that with the throttle cracked a little or the idle screw turned in a couple turns, the bike fires right up. But, manually holding the throttle open during warm-up is a pain. If I use the idle screw, then I have to dial the idle back down once it is warm, and then back up the next time I cold start.
So, what I have been thinking about is how to utilize MegaSquirt II's ability to govern any idle control system and possibly using the GSX-R throttle bodies' feature WITHOUT the cable.
So far, I have thought about the possibility of using an idle air control valve and hooking it up to feed the additional air in through the intake boot ports. This would obviously not incorporate the built in mechanism on the TB's.
My other idea was to use a simple solenoid of some kind as an on/off that pushes the built in cam mechanism open during the warm up period.
Any ideas are welcome (sort of). I could use a cable if I wanted to (and will if I absolutely have to, but this thread is about alternatives). So, please don't recommend it.
thanXS
thanXS
